configure ASA 5505
Hello, This is the first time I am setting up a ASA5505 using ASDM but no luck yet. My ISP provided my block of 16 public ip addresses with Static IP. How can I configure theses ip on asa 5505 properly, information as mention below: WAN IP: 186.165.180.198 Gatway: 186.165.180.199 Subnet mask: : 255.255.255.252 ----------------------------------- LAN SUBNET: 180.185.160.208/28 16 public ips: 180.185.160.208 – 180.185.160.223 Gateway: 180.185.160.209 Mask 255.255.255.240 --------------------------------------- I tried This: Outside: 186.165.180.198, mask: : 255.255.255.252 INside IP: 180.185.160.210, mask: 255.255.255.240 enable dhcp server: Start ip: 180.185.160.211 - end ip: 180.185.160.222 route (outside) 0.0.0.0 0.0.0.0 186.165.180.199 ..........................but its not working, Please help me to configure these setting correctly on asa 5505
1 ACCEPTED SOLUTION
Well I'm running out of ideas
Well I'm running out of ideas. I can't figure out what is wrong...
What I think is strange is that you can't ping 8.8.8.8, which means that your ISP is either blocking your IP address (186.165.180.198), doesn't tell other ISP about that subnet, blocking ICMP or blocking connections to 8.8.8.8. You should try to ping other IP addresses and see if it is just 8.8.8.8 not working.
Also another thing that is a bit strange is that your gateway is using a broadcast address on the interface.
You were earlier telling me something that if you set up a Mikrotik router with a NAT exempt rule, it worked? Maybe your ISP is blocking your IP address on the ASA and allows only your block of IP addresses? If you want to try, I think this is the correct configuration for this: (Or you could remove the NAT configuration all together)
access-list EXEMPT extended permit ip 180.185.160.208 255.255.255.240 any
nat (inside) 0 access-list EXEMPT
One last troubleshooting thing you could do is this:
capture TEST type asp-drop acl-drop
capture TEST
And then send some traffic through your ASA and then look at what the capture says by typing this:
show capture TEST
If this doesn't reveal anything I would start from scratch, by typing configure factory-default. And just do the basic config and see if it works.
HiWhat is not working? Host
What is not working? Host not getting IP address from DHCP pool or no internet access?
What will you use the public IP address to?
Post your running-config file.
h.grankvist, I can get ip
h.grankvist, I can get ip address and dns on my pc but no internet access. What so far I know is that:
 ISP will be routing the 180.185.160.208/28 block to over the wan static ip 186.165.180.198
ASA configure file:
ASA Version 8.2(5)
hostname asa
names
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
 switchport access vlan 5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
 nameif inside
 security-level 100
 ip address 180.185.160.210 255.255.255.240
interface Vlan2
 nameif outside
 security-level 0
 ip address 186.165.180.198 255.255.255.252
interface Vlan5
 no nameif
 security-level 50
 no ip address
regex domainlist1 "\.youtube\.com"
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group protocol TCPUDP
 protocol-object udp
 protocol-object tcp
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 101 interface
nat (inside) 101 0.0.0.0 0.0.0.0
route outside 186.165.180.197 255.255.255.252 186.165.180.199 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
http 180.185.160.0 255.255.255.0 inside
http 180.185.160.0 255.255.255.240 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto ca trustpoint _SmartCallHome_ServerCA
 crl configure
crypto ca certificate chain _SmartCallHome_ServerCA
 certificate ca 6ecc7aa5a7032009b8cebcf4e952d491
Thanks for helping me,
Im not expert on networking
Im not expert on networking but just want to mention one thing that will help you. I tried this network setup on Mikrotik router. This network only work with this NAT setting on mikrotik router:
NAT rule to exclude source ip 180.185.160.208/28
add action=masquerade chain=srcnat src-address=!180.185.160.208/28 out-interface=wan
but i really do not know how to setup this thing on asa 5505
I think your problem is that
I think your problem is that you dont have a default route.
So add this:
route outside 0 0 186.168.180.199 1
And you can remove this (it is not needed):
I can't help you with the NAT, I only know 8.3 and later code for NAT. But I dont think there is a problem. At the moment the ASA translates all IP addresses on the inside network to the IP address of the outside interface.
thanks for your quick reply,
thanks for your quick reply, I tried this new route but no luck so far, here is configure file:
ASA Version 8.2(5)
hostname asa
enable password
passwd
names
interface Vlan1
 nameif inside
 security-level 100
interface Vlan2
 nameif outside
 security-level 0
interface Vlan5
 no nameif
 security-level 50
 no ip address
ftp mode passive
 protocol-object udp
 protocol-object tcp
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 186.165.180.199 1
http server enable
 crl configure
please help me
Hmm, okay.Well lets see what
Hmm, okay.
Well lets see what packet-tracer says. Run this command:
packet-tracer input inside tcp 180.185.160.210 54322 123.123.123.123 132
Can you ping your gateway (186.165.180.199) from the ASA?
If you can, can you ping 8.8.8.8 from you ASA?
please check detail of tracer
please check detail of tracer:
asa> enable
Password: *******
asa# packet-tracer input inside tcp 180.185.160.210 54322 123.123.123.123 132
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         outside
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
ping result:
ping
Sending 5, 100-byte ICMP Echos to 186.165.180.199, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/102/400 ms
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 0 percent (0/5)
thanks for your help,I'm looking forward to your reply
capture TEST
show capture TEST
Hello H.Grankvist, I tried
Hello H.Grankvist, I tried this: access-list EXEMPT extended permit ip 180.185.160.208 255.255.255.240 any
nat (inside) 0 access-list EXEMPT....
Guess what? IT's working.Thank you so much h.grankvist. Thanks for your quick reply, its really helped me.....
God bless you....
Hello h.grankvist ,I have one
Hello h.grankvist ,
I have one more question for you. How do i create User ID and Password for wifi users (using customer laptop mac address) on asa 5505 & set speed limit to customers? is it possible to create login page for wifi users on asa 5505?
thanks in advance
Hello againI think you would
Hello again
I think you would have to use a RADIUS server for this (which can be integrated into Active Directory on windows server).
You should create a new question about this, I can't help you with this.
 hello ranadeo01, First you
hello ranadeo01,
First you need to load the ASDM image on ASA and then use the command:
asdm image dosk0:/asdm888.bin     (assuming the ASDM image name is asdm888.bin)
then on the ASA CLI issue the following commands:
http server enable
http 1.0.0.0 255.0.0.0 inside      (assuming your machine is in 1.0.0.0 subnet belonging to INside interface)
then from your browser put your ASA managment IP and hit enter, it will open HTTPS management to the ASA from the browser...
about the NAT i would suggest you to review the following links:
http://www.youtube.com/watch?v=CNMrFksSdrc
http://www.youtube.com/watch?v=F1hK5iFlNKE
Kind Regards,
/Osama
osamasalmanThanks for the
osamasalman
Thanks for the reply, I can access asa 5505 using ACL and asdm. Only problem is that i can not access to internet through asa 5505. please check my configure file
thanks
God bless you....
239
