crypto isakmp key invalid input. not able to add pre-share key to cisco asa
Hello!
I am setting up a site to site VPN using 2 cisco asa the remote site is configured with a dynamic IP and the main office with a static IP.
after the initial ISAKMP setup: on remote asa
crypto isakmp policy 1
 encr 3des
 hash md5
 authentication pre-share
 group 2
 lifetime 86400
I am running the following command to add the pre-share key:
crypto isakmp key xxxxxxxxx address 0.0.0.0 0.0.0.0
but I am getting an error:
invalid input under "key"
any idea?
thanks
Everyone's tags (2)
1 REPLY
Hello, If you are seeting up
If you are seeting up the side has static IP address, and we are talking about an ASA and not a router, that command you are setting is not used on ASA, it is for IOS routers, so to set up the tunnel group for dynamic connections you will have to this:
1. Set up the pre-shared key for Dynamic connections(0.0.0.0 0.0.0.0):
tunnel-group DefaultL2LGroup ipsec-attributes
 pre-shared-key <Pre_shared key value>
2. The create a transform set and a dynamic conenction associated to it:
crypto ipsec transform-set myset esp-3des esp-md5-hmac --> this has to match the transform set of the ASA placed on the other side
crypto dynamic-map cisco 10 set transform-set myset  --> Dynamic Map associated to the Transform set
3. The you will have to associate the correspondent Dynamic Map to a Crypto MAP:
crypto map dyn-map 2000 ipsec-isakmp dynamic cisco
This is all you have to do on the Dynamic Side.
Please don´t forget to rate
Best Regards,
David Castro,
332
