Establish a Remote VPN connection to my SA520 Firewall
Dear all
I buy for month ago the SA520 Firewall and now I try to establish a remote vpn connection to my SA520 Firewall. The SA520 is updated to Frimware 2.2.0.7 and my VPN Client is the Cisco 5.0.07.0410.
When I config with the VPN Wizard the IKE Policies, the VPN Policies, the IPSec Users and the Dynamic IP Range (192.168.12.110-192.168.12.120) I can build up a VPN connection and I get also the 192.168.12.110 IP Address on the VPN Client but I am not able to reage my LAN 192.168.10.0. On the WAN Site there I have DynDNS.
Can anybody tell me what I do wrong. Have I to configure a static route or an additional Firewall Rule? I tried in the past so lot of things and I have no clue what I do wrong...
Kind Regards
Adrian
Re: Establish a Remote VPN connection to my SA520 Firewall
In your VPN configuration you had to tell it what the local network is. Did you make it the 12.x network only or both the 12.x and 10.x networks? It needs to be both.
Shawn Eftink CCNA/CCDA Please rate all helpful posts and mark correct answers to assist others searching for solutions in the community.
Hi Shawn
My local Network is 10.x and the dynamic IP Range 12.x. When I will change the dynamic IP Range to 10.x then the SA520 tell me that this is not allowed... how can I make it to be both?
Here some information about the config... Could be that it can helps
IKE Policy Configuration
General
Policy Name:
VPN (grey)
Direction / Type:
Responder
Exchange Mode:
Aggressive
Local
Identifier Type:
FQDN
Identifier:
Local.com
Remote
Identifier Type :
FQDN
Identifier:
0.0.0.0
IKE SA Parameters
Encryption Algorithm:
AES-128
Authentication Algorithm:
SHA-1
Authentication Method:
Pre-Shared key
Pre-shared key:
Xxxxxxxxx
Diffie-Hellman (DH) Group:
Group 2(1024 bit)
SA-Lifetime (sec):
28800
Enable Dead Peer Detection:
Not tagged
Detection Period:
10   (grey)
Reconnect after failure count:
3   (grey)
Extended Authentication
XAUTH Configuration:
Edge Device
Authentication Type:
User Database
User Name:
Password:
VPN Policy Configuration
General
Policy Name:
VPN
Policy Type:
Auto Policy
Select Local Gateway:
Dedicated WAN
Remote Endpoint:
FQDN
0.0.0.0
Enable Mode Config:
Yes tagged
Enable NetBIOS?
Not tagged
Enable RollOver?
Not tagged
Local Traffic Selection
Local IP:
Grey   cannot enter something
Start IP Address:
End IP Address:
Subnet Mask:
Remote Traffic Selection
Remote IP:
Any
Start IP Address:
End IP Address:
Subnet Mask:
Manual Policy Parameters
SPI-Incoming:
SPI-Outgoing:
AES-128
Key-In:
Key-Out:
Integrity Algorithm:
SHA-1
Key-In:
Key-Out:
Auto Policy Parameters
SA Lifetime:
3600
AES-128
SHA-1
PFS Key Group:
yes tagged
DH Group 2 (1024 bit)
Select IKE Policy:
VPN
Redundant VPN Gateway Parameters
Enable Redundant Gateway:
Select Back- up Policy:
Failback time to switch
from back-up to primary:
(Seconds)
Dynamic IP Range
Dynamic IP Range Configuration
Tunnel Mode:
Split Tunnel
Start IP Address:
192.168.12.x   (cannot change to LAN 10.x will not be allowed from SA520)
End IP Address:
Primary DNS(Optional):
192.168.12.x
Secondary DNS(Optional):
Primary WINServer(Optional):
Secondary WINServer(Optional):
You might try adding an Access Rule that allows Source LAN Destination WAN Source IP 10.x Destination IP 12.x and another Access Rule with everything reversed.
Hi Shawn
Sorry for my additional question but i am not so familiar with Firewall and VPN.
This Access Rule are two rules which I have make in the Firewall. Is that right? So no static Route? Can you hiev me an example how i have to configur this?
Kind Regards
Adrian
Firewall -> IPv4 Rules
Rule 1
From Zone - LAN
To Zone - WAN
Service - ANY
Action - ALLOW Always
Source Hosts - 192.168.10.1-192.168.10.254
Destination Hosts - 192.168.12.110-192.168.12.120
Rule 2
From Zone - WAN
To Zone - LAN
Service - ANY
Source Hosts - 192.168.12.110-192.168.12.120
Destionation Hosts - 192.168.10.1-192.168.10.254
If you already have a BLOCK Always Access Rule, ensure you move these two rules so that they are processed before the BLOCK Always Access Rule.  I can't promise that this will fix it, but this is similar to how you can address this in an ASA.  If that doesn't fix it, I would delete both of these new rules, so you don't forget about them.
I must admit that I'm a little handicapped here since I don't have a SA520 I can test with and have been utilizing the SA500 Emulator up to this point.  Let me know the results of your efforst and I'll see if I can't continue to assist.
Shawn Eftink
CCNA/CCDA
Thank you Shawin
For the next three dasys i am not able to Test it. But when I will be back i Five you as fast as possible a feetback.
Thank you
Hi Shawin
I tried in the last days to establish a VPN connection  but without success. I don't know what I should do to get this .... Do  you have an answer for me or is there someone which is familiar with the  SA-520.
Kind Regards
Adrian
Adrian,
I'd recommend opening a case with SMB support. I'm sorry I wasn't able to assist you more.
http://www.cisco.com/cisco/web/solutions/small_business/small_business_support_and_resources.html
726
