Community Member
Hi Dude
I plan to start small cisco security business. I need guidance how to start the business.
S.Sakthidasan.
1 REPLY
Re: Hi Dude
The first step is to become a Cisco Registered Partner if you are not already (see attached document).  Once that is done you need to work through the courses in the Small Business University found here. (Partner CCO login required).  There are many courses offered there, some specific to Security.
Good Luck!
300
