Community Member
Interface Rate Limit Drops
We are seeing rate limit drops on a new internet ethernet connection. I can't seem to find an explanation that does not have Qos in the reason for the rate limit drops.
Here is what we see on a ASA 5520 running 6.4.
Interface GigabitEthernet1/2 "outside", is up, line protocol is up
  Hardware is VCS7380 rev01, BW 1000 Mbps, DLY 10 usec
        Auto-Duplex(Full-duplex), Auto-Speed(100 Mbps)
        Input flow control is unsupported, output flow control is unsupported
        Media-type configured as RJ45 connector
        Description: Outside connection to TWT port 0/1
        MAC address, MTU 1500
        IP address, subnet mask
        189630202 packets input, 151713633224 bytes, 0 no buffer
        Received 201 broadcasts, 0 runts, 0 giants
        0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
        0 L2 decode drops
        168620541 packets output, 79755781476 bytes, 0 underruns
        0 pause output, 0 resume output
        0 late collisions, 0 deferred
        0 input reset drops, 0 output reset drops
        406895 rate limit drops
        input queue (blocks free curr/low): hardware (0/0)
        output queue (blocks free curr/low): hardware (0/0)
  Traffic Statistics for "outside":
        189563376 packets input, 148146509320 bytes
        169040114 packets output, 76924197238 bytes
        2782075 packets dropped
      1 minute input rate 1398 pkts/sec,  1258861 bytes/sec
      1 minute output rate 1195 pkts/sec,  418651 bytes/sec
      1 minute drop rate, 8 pkts/sec
      5 minute input rate 2109 pkts/sec,  1888351 bytes/sec
      5 minute output rate 1881 pkts/sec,  1019056 bytes/sec
      5 minute drop rate, 11 pkts/sec
When I do a 'sh run int g1/2' it shows nothing but the actual interface so I think that its not being dropped by us. The interface utilization is low so I dont think thats the issue.
I am sure there is an easy explanation of why there are packets dropping, does anyone have it?
Couple of items.
  1. This is the SMB Security Community and I wouldn't suggest questions related to an ASA 5520, which is definitely not a SMB device, be asked here.  This would probably be the more appropriate community.
  2. That said, you mentioned you're running 6.4.  Have you looked into upgrading the latest firmware?  I believe the current is 9.x.
    • If not, I would recommend starting there.  I will caution that there were a number of changes in 8.x and 9.x so be sure to read up on release notes prior to the upgrade or consider leveraging a Cisco Partner to assist.
      • BTW, yes we are a Cisco Partner, have vast experience with ASAs, and would be happy to assist.  Feel free to send me a private message if you would like.
Shawn Eftink
Please rate all helpful posts and mark correct answers to assist others searching for solutions in the community.
Shawn Eftink CCNA/CCDA Please rate all helpful posts and mark correct answers to assist others searching for solutions in the community.
Community Member
Thanks, I moved it.
Also had wrong version... I was looking at asdm version, whoops.
