Isa 570 firmare 1..2.17 vpn failover not return to primary vpn
Hello, i have add a vpn failover to my primary ipsec lan to lan.
When i test the backup it's  ok.
If fhe primary remote gateway not respond, vpn go down and disable, The backup vpn switch to enable and go up.
When the primary remote gateway tespond, the backup vpn go down and disable but tre primary vpn not return in enable state.
If i connect the vpn manual go up.
Where is the problem?
Thank
Best regards
Aondio Carlo
41
