ISA570 - SNMP on WAN Interface
anyone collecting SNMP statistics over the WAN Interface? I can walk the tree from the DEFAULT Lan, but when I set trusted host to 0.0.0.0 I don't get a resonse from the WAN IF. Created a new firewall rule for this, doesn't help.
Any ideas?
Michael
Please rate all helpful posts
Michael Please rate all helpful posts
Re: ISA570 - SNMP on WAN Interface
I'm not, but you did add a permit for source ANY (or whatever IP) to WAN service SNMP and it still didn't work? I know technically speaking to polling SNMP over the Internet is a security risk because it's all clear text. I wonder if Cisco has it off for WAN with no means of turning it on.
Shawn Eftink CCNA/CCDA Please rate all helpful posts and mark correct answers to assist others searching for solutions in the community.
Yep, I add a rule for SNMP, also I saw some hitcounts on the rule (but have accept), but no action.
I did a capture on the WAN seeing the inbound SNMP but no reply.
Seems that it's only allowed on the LAN IF
Michael
I'm assuming you're using SNMP v1/v2.  Have you tried SNMP v3?  Since it includes security, including encryption, it may be that SNMP access via the WAN interface is limited to v3.  It uses the same TCP/UDP Ports of 161/162 if you want to try it.
Shawn Eftink
CCNA/CCDA
I found the error, under Remote Administration, the Allow Address must match your source, even if you set 0.0.0.0 (like recommended from the docs)
Michael
What??!! That sounds more like a bug than a fix. Are you going to open a case with SBSC so they can address it? Nice catch nonetheless.
Hi Ciscomax,
We cannot reproduce this issue. Could you please send me your
system diagnostic files ? or open a case with SBCS.
thanks
Wei
I'm fine with my solution, thanks
Michael
1096
