ISA570W reboot daily
I got a problem with my Cisco ISA570W Firewall.
I set up an ipsec site to site vpn between two ISA570W and everyday, one of my ISA reboot at the same time at 12:09 AM.
There is no schedule configured and I don't know why it reboot everyday.
It 's a problem because when it reboots, the vpn doesn't mount alone, and I need to reboot manually the second ISA to make work the vpn.
Someone has ever had this problem ?What can I do to solve it ? Because it's very annoying....
Thank You !
1 REPLY
EOL and no more support on
EOL and no more support on this crap!!!!
But I was looking for such a feature on the ISA device. How the hell you have enabled this? :-)
But here are some tips for your problem:
1. Flash both (!) bios or rom's with the latest firmware.
2. Do a factory reset
3. DON'T use your current config and setup from scratch
Don't know why but even if you have the latest firmware installed on it this will solve a lot of problems if you do it every 6 month. But don't ask me why. It's working.
55
