Community Member
ISA570W Teleworker Client Input Field
Hi all,
We ran into an issue with the teleworker client group password field not allowing for a long group password. The input field allows for 31 characters and the password I've been given is 32 characters long. Unless there's another way of getting that group password into the configuration, the provider of that password will need to change it.
Perhaps there are work arounds for this issue that I'm missing?
Thanks!
Everyone's tags (2)
1 REPLY
Bronze
Dear Bill,
Thank you for reaching the Small Business Support Community.
Unfortunately I see no way around on this ISA Teleworker VPN Client password setup.  Just in case and if you would like to have a second opinion I's suggest you to contact the Small Business Support Center directly;
  https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Please do not hesitate to reach me back if there is anything I may assist you with in the meantime.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
355
