Community Member
MPLS on Lan switch
Having problems getting two sites communicating over a MPLS network.  Both sites have an Internet Leg of the MPLS which is connected to the ASA and a LAN leg which is connected to a switch on an inside interface.  Both sites have the ASA as the default gateway for all computers.  Both have a static route in the ASA pointing to the MPLS circuit to get to the other network.
Site A---ASA-192.168.1.1
Site A---MPLS-192.168.1.254
Site A-Server 192.168.1.20
Site B ASA 192.168.2.1
Site B MPLS 192.168.2.254
Site B Server 192.168.2.20
Site A
Internet-- 5505---Switch---MPLS------>
                                 L ----Servers
SiteB
Internet-- 5510---Switch---MPLS------>
                                 L ----Servers
If I put a static route on the servers in site a bypassing the ASA for traffic to site B pings/connectivity is fine.  Without the static route it appears the traffic goes to the ASA and dies.
I have added the same-security-traffic permit intra-interface command but it hasn't helped.
ASA version is 9.1(1)
ASDM version is 7.1(1)
Community Member
Out of curiosity if you show
Out of curiosity if you show your arp table on a client are all of the address pointing to the same MAC address? Your ASAs may be doing arp proxy.
no sysopt noproxyarp interface ie inside
http://www.packetu.com/2011/11/07/the-asas-arp-behavior/
Hi ,Run packet-tracer command
Hi ,
Run packet-tracer command between source (192.168.1.20) to destination (192.168.2.20)  , paste the output , to investigate further .
sandy
111
