Community Member
Old configuration after power loss to Primary in ASA 5200 Active\Active pair
I have two ASA 5200's in a active\active pair running 8.2. The power was lost to the primary device, was restored. but now the configuration, ip addreses etc are old (over a year). what would cause this? When ever we make a change ot the config in the ADSM we always "Apply" and "Save", should we do more than this?
Stuart
Everyone's tags (1)
1 REPLY
You said that you are running
You said that you are running active/active but then you said that the power was lost to the "primary unit." Can you confirm if you are running active/standby or active/active with virtual contexts
Thank you for rating helpful posts!
66
