Opening a second http port on Cisco router and ASA 5505
Hallo,
I have a cisco router and ASA. The internet link connects to the router first and then  to firewall. I have two internal web servers one of them is HTTPS and one is http. 192.168.11.112 is my HTTPS email server and currently it can be accessed from outside. I have another web application that i want also to be accessed fro outside but i am having challenges. internally it is accessed like : 192.168.11.7:86/application.
My router Configs are :
Router Configs
Router_HQ #sh run
Building configuration...
interface GigabitEthernet0/0
 description HQ_LAN
 ip address 10.1.1.1 255.255.255.248
 ip nat inside
 ip virtual-reassembly
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description LINK TO ISP
 ip address 61.239.128.122 255.255.255.252
 ip nat outside
 duplex auto
 speed auto
 crypto map VPN
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static tcp 192.168.11.112 25 61.239.128.122 25 extendable
ip nat inside source static tcp 192.168.11.112 110 61.239.128.122 110 extendable
ip nat inside source static tcp 192.168.11.112 443 61.239.128.122 443 extendable
ip nat inside source static tcp 192.168.11.112 587 61.239.128.122 587 extendable
ip route 0.0.0.0 0.0.0.0 61.239.128.121
ip route 192.168.11.0 255.255.255.0 10.1.1.2 name HQ_Firewall
ip access-list extended INTERNET
 deny   ip 192.168.11.0 0.0.0.255 192.168.12.0 0.0.0.255
 deny   ip 192.168.11.0 0.0.0.255 192.16811.0.0 0.0.0.255
 permit ip 192.168.11.0 0.0.0.255 any
ip access-list extended Vic
 permit ip 192.168.11.0 0.0.0.255 192.168.12.0 0.0.0.255
ip access-list extended RMcc_TUNNEL
 permit ip 192.168.199.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 111 permit ip 192.168.11.0 0.0.0.255 192.168.10.0 0.0.0.255
route-map INTERNET permit 10
 match ip address INTERNET
ASA firewall:
HQ_Firewall# sh run
ASA Version 7.2(3)
interface Vlan1
 nameif inside
 security-level 100
 ip address 192.168.11.2 255.255.255.0
interface Vlan2
 nameif outside
 security-level 0
 ip address 10.1.1.2 255.255.255.248
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
access-list mail extended permit tcp any host 192.168.11.112 eq smtp
access-list mail extended permit tcp any host 192.168.11.112 eq pop3
access-list mail extended permit tcp any host 192.168.11.112 eq 3000
access-list mail extended permit ip 192.168.10.0 255.255.255.0 192.168.11.0 255.25        5.255.0
access-list mail extended permit ip 192.168.12.0 255.255.255.0 192.168.11.0 255.25        5.255.0
access-list mail extended permit tcp any host 192.168.11.112 eq https
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
access-group mail in interface outside
route outside 0.0.0.0 0.0.0.0 10.1.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
aaa authentication ssh console LOCAL
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
http server enable 444
http 0.0.0.0 0.0.0.0 outside
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh 192.168.11.0 255.255.255.0 inside
ssh 10.1.1.1 255.255.255.255 outside
ssh timeout 30
ssh version 2
console timeout 0
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
1 REPLY
Hi Saleem,If the service is
Hi Saleem,
If the service is currently listening on TCP port 86 - and you would like inbound connections via the Internet to use TCP port 80 (HTTP) - then you would need to NAT inbound connections from 80 to 86 on your Cisco router and permit that port on both your devices.
ip nat inside source static tcp 192.168.11.17 86 61.239.128.122 80 extendable
access-list mail extended permit tcp any host 192.168.11.7 eq 86
Please rate helpful posts.
89
