Port Forward Failing
I am working with a potential customer.  I need to do a port forward rule on his ASA 5505.  I have done this numerous times and actually have it working on my own ASA.  There is something within his config that is causing this to not work.  I need to forward UDP 5008 from the outside to an inside server 12.4.14.17.
We have tried Packet Tracer to see where it is failing as well.  I do believe it is one of the NAT rules.  Below is the config he sent me. I know he has created a number of network objects that are the same, we are going to clean that up, but for now just need to see what I can do to get this to work. Any help will be greatly appreciated.
 Saved
ASA Version 8.3(2)
hostname ciscoasa
enable password IyuqcUIHRBPhCMFO encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
 speed 10
 duplex full
 nameif SouthernLight_Outside
 security-level 0
 ip address 69.x.x.x 255.255.255.248
interface Ethernet0/1
 nameif Intrado_Inside
 security-level 100
 ip address 10.4.15.250 255.255.240.0
interface Ethernet0/2
 nameif inside2
 security-level 100
 ip address 10.5.15.254 255.255.240.0
interface Ethernet0/3
 nameif Enroute_Inside
 security-level 100
 ip address 12.4.14.250 255.255.255.0
interface Management0/0
 shutdown
 nameif management
 security-level 100
 ip address dhcp setroute
 management-only
boot system disk0:/asa832-k8.bin
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
object network any_inside
 subnet 0.0.0.0 0.0.0.0
object network NETWORK_OBJ_10.10.10.0_24
 subnet 10.10.10.0 255.255.255.0
object network NETWORK_OBJ_10.30.30.0_24
 subnet 10.30.30.0 255.255.255.0
object network Inside_Net
 subnet 10.4.0.0 255.255.0.0
object network RIP_server
 host 10.4.1.33
object service 9517_TCP
 service tcp source eq 9517
object service 9517_UDP
 service udp source eq 9517
object service 9519_TCP
 service tcp source eq 9519
object service 9519_UDP
 service udp source eq 9519
object network Enroute_Network
 subnet 12.4.14.0 255.255.255.0
object network Enroute_VPN_Pool
 subnet 12.12.12.0 255.255.255.0
object network A_69.x.x.x
 host 69.x.x.x
object network netmotion_private
 host 12.4.14.17
object network netmotion_public
 host 12.4.14.250
object service 5008_UDP
 service udp source eq 5008
object network Netmotion_Server
 host 12.4.14.17
object network nms
 host 12.4.14.17
object network nms1
 host 12.4.14.17
object network NetMotion
 host 12.4.14.17
access-list SRC_splitTunnelAcl standard permit 10.4.0.0 255.255.0.0
access-list SRC_splitTunnelAcl standard permit 12.4.14.0 255.255.255.0
access-list inside_access_in extended permit ip any any
access-list outside_access_in extended permit tcp any object RIP_server eq 9517
access-list outside_access_in extended permit tcp any object RIP_server eq 9519
access-list outside_access_in extended permit udp any object RIP_server eq 9517
access-list outside_access_in extended permit udp any object RIP_server eq 9519
access-list outside_access_in extended permit udp any object netmotion_private eq 5008
access-list Enroute_Inside_access_in extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu SouthernLight_Outside 1500
mtu Intrado_Inside 1500
mtu inside2 1500
mtu Enroute_Inside 1500
mtu management 1500
ip local pool VPN_Pool 10.10.10.2-10.10.10.254 mask 255.255.255.0
ip local pool Enroute_VPN_Pool 12.12.12.2-12.12.12.254 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-635.bin
no asdm history enable
arp timeout 14400
nat (Intrado_Inside,SouthernLight_Outside) source static Inside_Net Inside_Net destination static NETWORK_OBJ_10.10.10.0_24 NETWORK_OBJ_10.10.10.0_24
nat (Intrado_Inside,SouthernLight_Outside) source static RIP_server interface service 9519_TCP 9519_TCP
nat (Intrado_Inside,SouthernLight_Outside) source static RIP_server interface service 9519_UDP 9519_UDP
nat (Intrado_Inside,SouthernLight_Outside) source static RIP_server interface service 9517_TCP 9517_TCP
nat (Intrado_Inside,SouthernLight_Outside) source static RIP_server interface service 9517_UDP 9517_UDP
nat (inside2,SouthernLight_Outside) source static Inside_Net Inside_Net destination static NETWORK_OBJ_10.10.10.0_24 NETWORK_OBJ_10.10.10.0_24
nat (Enroute_Inside,SouthernLight_Outside) source static Enroute_Network Enroute_Network destination static Enroute_Network Enroute_Network
nat (Enroute_Inside,SouthernLight_Outside) source static Enroute_Network Enroute_Network destination static NETWORK_OBJ_10.10.10.0_24 NETWORK_OBJ_10.10.10.0_24
 nat (any,SouthernLight_Outside) dynamic interface
 nat (Enroute_Inside,SouthernLight_Outside) static interface service udp 5008 5008
access-group outside_access_in in interface SouthernLight_Outside
access-group inside_access_in in interface Intrado_Inside
access-group Enroute_Inside_access_in in interface Enroute_Inside
route SouthernLight_Outside 0.0.0.0 0.0.0.0 69.85.255.89 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
Here's a how to video on
Here's a how to video on YouTube using ASDM
https://www.youtube.com/watch?v=MW2_Rc9vj3o
Here is a pretty good link for CLI or ASDM config as well
https://rowell.dionicio.net/configuring-nat-for-a-public-server-using-same-outside-interface/
Thanks Michael.
Thanks Michael.  Unfortunately that is basically the same process we used.  In the configuration, we basically have NAT(INSIDE,OUTSIDE) static interface service UDP 5008 5008 and the ACL in place.  I am thinking some other NAT is causing this to fail. Could this be what is causing the issue:  nat (any,SouthernLight_Outside) dynamic interface
What did the output of packet
What did the output of packet tracer show? Here is a good doc if you need any clarification on it
https://supportforums.cisco.com/document/29601/troubleshooting-access-problems-using-packet-tracer
66
