Problem with SA Lifetime VPN
I've a problem with 2 VPN IPsec between 2 ASA. One in a central Office and a second in a remote Site.
The parameters in each side are the same.
When the SA lifetime expired, the VPN don't work. The VPN is up but no traffic passed inside. We are obliged to go down the VPN and go up the VPN manually.
After, the traffic passes inside the VPN and the users will work normally.I check the configuration both sides and they are exactly similar.
So, what's the problem? I've already change the ASA but no success.
I've also the same configuration in an another remote site (for the same central office) and we don't have a problem. The VPN is up continously.
Thanks for the response
1 REPLY
Re: Problem with SA Lifetime VPN
Please post you query at the following forum.
http://forums.cisco.com/eforum/servlet/NetProf?page=main
Some one with ASA knowledge will definitely get back to you.
This forum is for SA500 series products.
Sorry for the inconvenience.
Biraja
621
