Problems when trying to surf the Internet through a SSL VPN tunnel
I have a small/big problem, I have a customer who have the need for the possibility to surf the internet through the SA500W when they are connected through a SSL VPN tunnel in to their network. I am not using a Split Tunnel. What I have seen until now, when you run IPCONFIG/ALL the default gateway for the SSL VPN IP settings is 0.0.0.0. Is this the problem and if so, how can this be solved?
Thanks in advance!
Brg
Niklas Eklov
227
