Remote VPN between ASA5505 and Netscreen SSG140
Dears,
I'm trying to set up a VPN between an ASA 5505 and  SSG40Juniper and the VPN keep flaping:
Nov 27 04:47:27 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, NP encrypt rule look up for crypto map TEST 1 matching ACL ACL_VPN: returned cs_id=cd2e0998; encrypt_rule=cd39bd50; tunnelFlow_rule=cd488220
Nov 27 04:47:27 [IKEv1]Group = 89.XXX, IP = 89.XXX, Security negotiation complete for LAN-to-LAN Group (89.XXX)  Responder, Inbound SPI = 0xb98f5dbe, Outbound SPI = 0xddd1484a
Nov 27 04:47:27 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, IKE got a KEY_ADD msg for SA: SPI = 0xddd1484a
Nov 27 04:47:27 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, Pitcher: received KEY_UPDATE, spi 0xb98f5dbe
Nov 27 04:47:27 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, Starting P2 rekey timer: 3060 seconds.
Nov 27 04:47:27 [IKEv1]Group = 89.XXX, IP = 89.XXX, PHASE 2 COMPLETED (msgid=f46e307a)
Nov 27 04:47:31 [IKEv1]IKE Receiver: Packet received on 81.1XXX:500 from 89.XXX:500
Nov 27 04:47:31 [IKEv1]Group = 89.XXX, IP = 89.XXX, Duplicate Phase 2 packet detected.  Retransmitting last packet.
Nov 27 04:47:31 [IKEv1]Group = 89.XXX, IP = 89.XXX, Responder resending lost, last msg
Nov 27 04:47:31 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, Starting P2 rekey timer: 3056 seconds.
Nov 27 04:47:31 [IKEv1]Group = 89.XXX, IP = 89.XXX, PHASE 2 COMPLETED (msgid=f46e307a)
Nov 27 04:47:35 [IKEv1]IKE Receiver: Packet received on 81.XXX:500 from 89.XXX:500
Nov 27 04:47:35 [IKEv1]Group = 89.XXX, IP = 89.XXX, Duplicate Phase 2 packet detected.  Retransmitting last packet.
Nov 27 04:47:35 [IKEv1]Group = 89.XXX, IP = 89.XXX, Responder resending lost, last msg
Nov 27 04:47:35 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, Starting P2 rekey timer: 3052 seconds.
Nov 27 04:47:35 [IKEv1]Group = 89.XXX, IP = 89.XXX, PHASE 2 COMPLETED (msgid=f46e307a)
Nov 27 04:47:38 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, Sending keep-alive of type DPD R-U-THERE (seq number 0x1a4070b7)
Nov 27 04:47:38 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, constructing blank hash payload
Nov 27 04:47:38 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, constructing qm hash payload
Nov 27 04:47:38 [IKEv1]IP = 89.XXX, IKE_DECODE SENDING Message (msgid=8977946c) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Nov 27 04:47:38 [IKEv1]IKE Receiver: Packet received on 81.XXX:500 from 89.XXX:500
Nov 27 04:47:38 [IKEv1]IP = 89.XXX, IKE_DECODE RECEIVED Message (msgid=8e9a1247) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Nov 27 04:47:38 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, processing hash payload
Nov 27 04:47:38 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, processing notify payload
Nov 27 04:47:38 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, Received keep-alive of type DPD R-U-THERE-ACK (seq number 0x1a4070b7)
Nov 27 04:47:39 [IKEv1]IKE Receiver: Packet received on 81.XXX:500 from 89.XXX:500
Nov 27 04:47:39 [IKEv1]Group = 89.XXX, IP = 89.XXX, Duplicate Phase 2 packet detected.  Retransmitting last packet.
Nov 27 04:47:39 [IKEv1]Group = 89.XXX, IP = 89.XXX, Responder resending lost, last msg
Nov 27 04:47:39 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, Starting P2 rekey timer: 3048 seconds.
Nov 27 04:47:39 [IKEv1]Group = 89.XXX, IP = 89.XXX, PHASE 2 COMPLETED (msgid=f46e307a)
Nov 27 04:47:43 [IKEv1]IKE Receiver: Packet received on 81.XXX:500 from 89.XXX:500
Nov 27 04:47:43 [IKEv1]Group = 89.XXX, IP = 89.XXX, Duplicate Phase 2 packet detected.  Retransmitting last packet.
Nov 27 04:47:43 [IKEv1]Group = 89.XXX, IP = 89.XXX, QM FSM error (P2 struct &0xcd58eee8, mess id 0xf46e307a)!
Nov 27 04:47:43 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, IKE QM Responder FSM error history (struct &0xcd58eee8)  <state>, <event>:  QM_DONE, EV_ERROR-->QM_ACTIVE, EV_RESEND_MSG-->QM_ACTIVE, NullEvent-->QM_ACTIVE, EV_VM_START-->QM_ACTIVE, EV_ACTIVE-->QM_RSND_LST_MSG, EV_RESET_LIFETIME-->QM_RSND_LST_MSG, EV_IS_REKEY_SECS-->QM_RSND_LST_MSG, EV_RESEND_MSG
Nov 27 04:47:43 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, sending delete/delete with reason message
Nov 27 04:47:43 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, constructing blank hash payload
Nov 27 04:47:43 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, constructing IPSec delete payload
Nov 27 04:47:43 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, constructing qm hash payload
Nov 27 04:47:43 [IKEv1]IP = 89.XXX, IKE_DECODE SENDING Message (msgid=57422aa9) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 64
Nov 27 04:47:43 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, IKE Deleting SA: Remote Proxy 172.24.0.0, Local Proxy 10.143.0.0
Nov 27 04:47:43 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, IKE SA MM:08bcc57b rcv'd Terminate: state MM_ACTIVE  flags 0x00000042, refcnt 1, tuncnt 0
Nov 27 04:47:43 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, IKE SA MM:08bcc57b terminating:  flags 0x01000002, refcnt 0, tuncnt 0
Nov 27 04:47:43 [IKEv1 DEBUG]Group = 89.XXX, IP = 89.XXX, constructing IKE delete payload
Nov 27 04:47:43 [IKEv1]IP = 89.XXX, IKE_DECODE SENDING Message (msgid=c364409e) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 76
Nov 27 04:47:43 [IKEv1 DEBUG]Pitcher: received key delete msg, spi 0xb98f5dbe
Nov 27 04:47:43 [IKEv1]Group = 89.XXX, IP = 89.XXX, Session is being torn down. Reason: Lost Service
Nov 27 04:47:43 [IKEv1]Ignoring msg to mark SA with dsID 1658880 dead because SA deleted
On the Cisco side
crypto ipsec ikev1 transform-set ESP-3DES-ESP-MD5-HMAC esp-3des esp-md5-hmac
crypto ipsec security-association pmtu-aging infinite
crypto map TEST 1 match address ACL_VPN
crypto map TEST 1 set peer 89.XXX.XXX.XXX
crypto map TEST 1 set ikev1 transform-set ESP-3DES-ESP-MD5-HMAC
crypto map TEST interface outside
crypto ca trustpool policy
no crypto isakmp nat-traversal
crypto ikev1 enable outside
crypto ikev1 policy 1
 authentication pre-share
 encryption 3des
 hash md5
 group 2
 lifetime 86400
access-list ACL_VPN extended permit ip 10.143.0.0 255.255.0.0 172.24.0.0 255.255.0.0
On the juniper side:
set ike gateway "TO_XXX_ASA" address 81.XXX.XXX.XXX Main outgoing-interface "ethernet0/2" preshare "XXXXXXX" proposal "pre-g2-3des-md5"
set vpn "DATACENTER_XXX_ASA" proxy-id local-ip 172.24.0.0/16 remote-ip 10.143.0.0/16 "ANY"
set vpn "DATACENTER_XXX_ASA" gateway "TO_XXX_ASA" no-replay tunnel idletime 0 proposal "nopfs-esp-3des-md5"
set vpn "DATACENTER_XXX_ASA" monitor optimized rekey
set vpn "DATACENTER_XXX_ASA" id 0x78 bind interface tunnel.2
set vpn "DATACENTER_XXX_ASA" monitor source-interface ethernet0/2 destination-ip 10.143.0.1 optimized rekey
set vpn "DATACENTER_XXX_ASA" id 0x7b bind interface tunnel.2
PFS is disabled.
Any idea why I receive these errors?
Hey,anybody any idea on this
Hey,
anybody any idea on this problem? We encountered this problem also.
i can see in ASA log that phase1 is completed.
after that we get the msg for phase2 completed.
but followed with a "responder resending lost, last msg" this 3 times, than a QM FSM error and the tunnel being shut down on our end.
the other side, is getting an active SA, but ofc not working.
any idea?
5 Jan 23 2015 14:59:14 713120 Group = xx.xx.xx.xx, IP = xx.xx.xx.xx, PHASE 2 COMPLETED (msgid=440ce73e)
7 Jan 23 2015 14:59:18 713906 IKE Receiver: Packet received on yy.yy.yy.yy:500 from xx.xx.xx.xx:500
5 Jan 23 2015 14:59:18 713201 Group = xx.xx.xx.xx, IP = xx.xx.xx.xx, Duplicate Phase 2 packet detected.  Retransmitting last packet.
6 Jan 23 2015 14:59:18 713905 Group = xx.xx.xx.xx, IP = xx.xx.xx.xx, Responder resending lost, last msg
7 Jan 23 2015 14:59:18 715080 Group = xx.xx.xx.xx, IP = xx.xx.xx.xx, Starting P2 rekey timer: 27357 seconds.
5 Jan 23 2015 14:59:18 713120 Group = xx.xx.xx.xx, IP = xx.xx.xx.xx, PHASE 2 COMPLETED (msgid=440ce73e)
3x times
3 Jan 23 2015 14:59:30 713902 Group = xx.xx.xx.xx, IP = xx.xx.xx.xx, QM FSM error (P2 struct &0x00007fff2a9921f0, mess id 0x440ce73e)!
with kind regards,
Bernd
Hi Please read this document
Hi Please read this document,
http://azuretek.livejournal.com/4745.html
hope this helps.
378
