Community Member
Resolve Host
I occasionally get a auto generated email from my router with the following message:
2013-07-09 00:10:12 - Err - System:  sdsd: tcp_connect: Couldn't resolve host v1.sds.cisco.com
2013-07-09 00:10:12 - Err - System:  sdsd: open_connection: TCP connection failed on connection 0x1B1C2CB8
2013-07-09 00:10:12 - Err - System:  sdsd: http_get: Error: Failed to open connection to v1.sds.cisco.com
2013-07-09 00:19:31 - Err - System:  sdsd: tcp_connect: Couldn't resolve host v1.sds.cisco.com
2013-07-09 00:19:31 - Err - System:  sdsd: open_connection: TCP connection failed on connection 0x1B1C2CB8
2013-07-09 00:19:31 - Err - System:  sdsd: http_get: Error: Failed to open connection to v1.sds.cisco.com
Does cisco servers go down alot?  Other then the above message I'm not having any problems with the device.
Community Member
Re: Resolve Host
Hi Micheal,
I think you are recieving this error because the DNS settings are not configured propely on the device. Please can you mention the device name so I can post the appropriate configuration artlice to help resolve the issue.
Thank you,
Nnennaya Udochu
Community Member
Resolve Host
where is the problem on DNS configuration ?
Community Member
Resolve Host
It's all fixed and running like a champ.  thank you for the follow up.
Community Member
Resolve Host
Michael,
can you post your resolutions I'm getting the same error after perfoming the lates firmware on an ISA570
Community Member
Resolve Host
Sanron,
Seems the ISA550W is a little picky on DNS order entries.  I placed my internal first with outside as a secondary which caused the above error.  I switched them around and problem cleared itself.  My network skills are a little rusty and I don't quite get why that would make a difference since it should check both DNS entries before throwing up this error.  Can anyone answer this?
Did you test your video streaming yet?
Community Member
Resolve Host
thanks for the response.  the ISA was not able to resolve dns to ip after 5 days of upgrading.   decided to downgrade from the current firmware back to 1.2.15  and that solve the issues.  it appears inexplicable.
Resolve Host
Hi Sanron,
When you were running 1.2.17, was all dns resolution affected or were you just seeing similar errors that Micheal posted?
Brandon
Community Member
Resolve Host
Brando,
All DNS resolution was affected,  approximately four days of upgrading to 1.2.17  plus I was seeing similar error as Michael.   the end user were unable to browse the web,  and could not ping or trace within the ISA570.
Ron
Resolve Host
Hi Sanron,
Could you please send me your system diagnostic files for the DNS issue ?
or open a case with SBCS.
thanks
Wei
Community Member
Resolve Host
i don't have the latest firmware update. i'm not having an issue with 1.2.15  do you want the diagnostic file with 1.2.15?
thanks
Resolve Host
Hi Micheal,
With 1.2.17, some additional logging for Security Services was added and right now, those messages may be seen during normal operation.  In your case, it could mean that dns wasn't able to resolve with the internal dns server and then it was retried with the second dns server.  We would be more concerned if we saw a lot more of those errors per second.
We're working on reducing those errors to where it may be more of an issue.
Brandon
Community Member
Hi,i have change parameters
i have change parameters on wan interface and choice mode in DHCP Client et DNS from ISP.
Now i have no error in log.
2792
