RVS4000 - we require peer to have ID 'a.a.a.a', but peer declares 'b.b.b.b'
What is the good of advertising that you support NAT-T when clearly you don't.
Perhaps inbound client based VPN but what about outbound IPSec tunneling?
Consider this diagram...
Host 2 sits behind "RVS4000v2 Bravo" policy allow it to create an IPSec tunnel with the Cisco2821 sitting in this DMZ. This IPSec passes through a firewall where no translations happen and everything is perfect.
Unfortunately Host 1 is behind "RVS4000v2 Alpha" (c.c.c.c) on the Internet and because of security reasons, I cannot provide the Cisco2821 with direct Internet connecivity. The NAT'ing is working as all appears that the systems understand that there is NAT in path but yet the RVS4000-Alpha still gets spooked when the Phase2 Offer message is from b.b.b.b (Cisco 2821) and not a.a.a.a (Firewall NAT'ed Cisco 2821).
I have full IP capability as my devices do pass Phase 1 (as seen on the Cisco 2821)
ISAKMP: (4009):SA has been authenticated with a.a.a.a
ISAKMP: Trying to insert a peer b.b.b.b/a.a.a.a/500/,  and inserted successfully 47FE1CD8.
On The RVS4000:
Feb 18 14:08:14 - [VPN Log]: "PZ_Outside" #2: we require peer to have ID 'a.a.a.a', but peer declares 'b.b.b.b'
Feb 18 14:08:14 - [VPN Log]: "PZ_Outside" #2: sending encrypted notification INVALID_ID_INFORMATION to a.a.a.a:4500
On the Cisco2821(Inside the Firewall addressed a.a.a.a):
*Feb 18 19:02:45.847: ISAKMP: reserved not zero on HASH payload!
*Feb 18 19:02:45.847: %CRYPTO-4-IKMP_BAD_MESSAGE: IKE message from c.c.c.c failed its sanity check or is malformed
*Feb 18 19:02:45.847: ISAKMP:(4019):deleting node -712730088 error TRUE reason "Invalid payload"
Is there anyway to fix this? Is there no NAT-Traversal Enable function on the RVS4000? Is there no configurable item where I could tell the RVS4000 to accept the offer from a.a.a.a even if inside the offer, it is coming from b.b.b.b?
Thanks Chris
1 REPLY
Silver
Chris,
Hopefully someone from the products team will see this post and give some input as i know if the RVS4000 is behind another router this isn't a supported configuration.
Jasbryan
1637
