Community Member
SA 520 port forwarding problem
Hi Guys,
We have a Cisco SA 520 with 1.1.42 firmware. I would like to port forwarding from some servers which are connected on LAN. For example 192.168.1.7 is a web and mail server with open ports 80,443,143,25 . I made the ipv4 firewall rules. If I type in the web browser webmail.example.com on the PC1, everything is working correctly. But if I try to open webmail.example.com from a PC, like PC2 which is in my LAN, I get the configuration web page of SA520. If I try https the situation is same. I tried change the administrator port on the SA520, but nothing happend. Here is my network structure:
Thanks, your advice
Robert
1 ACCEPTED SOLUTION
Community Member
Re: SA 520 port forwarding problem
Hi Robert
The RC2 image I posted to you have this capability.
Please try it out
Henry
Community Member
Hi Robert
Please try it out
Henry
Community Member
Hi Henry,
The port forwarding looks working correctly with 1.1.62 RC2 firmware. When will be avaliable the stable version?
Robert
Community Member
I have this problem also, can I get that firmware also please?
Community Member
This is the URL of the firmware:
http://rapidshare.com/files/412268586/1.1.62_RC2.ZIP
Robert
Community Member
Many thanks for the help! What a great support
Thanks a million!
1944
