SA 520 SSH and VLANS
I have been testing a SA 520W. I have setup a couple different vlans, one for and one for voice. I have inter vlan routing enabled. When I try using SSH to get to my PBX it seems to only sort of work. I connect but it seems as though it is dropping packets. My PBX is a linux box so when I check the contents of a directory with the ls command it starts listing then will freeze for up to a minute before showing the rest. If I install another device with the same vlan config it works fine with no freezing.
Also any information on when/if the SA series will be able to functon as a DNS server?
This device is not much cheaper than an 881 I recently purchased but seems far more crippled.  What is the reason for this?
1 REPLY
Re: SA 520 SSH and VLANS
Hi Daniel,
Could you please provide me your router's configuration for
investigation ?
SA500 can not function as a DNS server, but the split DNS
functionality is going to be added soon.
Wei
1030
