SA 520W-wireless outside?
I'm thinking of getting an SA 520W for our small law firm. We now have a basic WAP for guests that is "inside" our PIX 506E; I want to put the wireless access "outside." Can anyone tell me if the SA 520W will do this?
Silver
We can setup a vlan called guess and then assign your guess SSID to that vlan so it will be segregated from the rest of your network. It won’t be outside the firewall but it will be segregated from the rest of your network.
If you’re talking about physically then NO the unit can’t be mounted outside.
Jasbryan.
Thanks, Jasbryan. I ended up deciding on an ASA 5505, mainly because of the similar commands, and the migration tool that Cisco appears to have removed from the website shortly after I bought the ASA
No worries, though. Cisco support has offered to do the migration from the PIX to the ASA for me. The ASA will let me set up a VLAN or a DMZ for the WAP.
Silver
Still a fantastic choice as i run ASA5505 at home
Jasbryan
745
