SA 540 and cisco vpn client issue
We bought a cisco SA 540 for our office. After upgrading firmware to latest release, I created without problems SSL connections.
But now I would like to setup an ipsec connection for cisco vpn client.
I am able to connect from outside but I can not access office network.
Some network information.
office network : 192.168.10.x
as 540 ip address : 192.168.10.254
ssl dhcp pool : 192.168.10.200 -> 192.168.10.230 ( works )
ipsec dynamic ip range : 192.168.11.200 -> 192.168.11.240
I setup it using doc available on cisco web site.
When I connect with cisco vpn client, I receive an ip from ipsec pool and also dns server address.
Gateway is equal to ip address given by ipsec but I can not ping / access office servers.
What is wrong with my configuration ?
Grégory Borysiak
Bronze
Hello Gregory,
Can you ping the default gateway? Can you ping the 192.168.10.254 address for the inside of your router?
If you can then it is a firewall setting on your clients, or perhaps both the client and the inside office network firewall settings that are blocking the traffic. This is not a hardware firewall but the Microsoft or 3rd party antivirus firewall blocking.
hope this helps.
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
Hello Randy,
I can ping the default gateway given by the vpn client as below :
   Suffixe DNS propre à la connexion. . . :
   Description. . . . . . . . . . . . . . : Cisco Systems VPN Adapter for 64-bit
Windows
   Adresse physique . . . . . . . . . . . : 00-05-9A-3C-78-00
   DHCP activé. . . . . . . . . . . . . . : Non
   Configuration automatique activée. . . : Oui
   Adresse IPv6 de liaison locale. . . . .: fe80::d5ba:2ca2:9e1e:6619%29(préféré
   Adresse IPv4. . . . . . . . . . . . . .: 192.168.11.200(préféré)
   Masque de sous-réseau. . . . . . . . . : 255.255.255.0
   Passerelle par défaut. . . . . . . . . : 192.168.11.1
   IAID DHCPv6 . . . . . . . . . . . : 486540698
   DUID de client DHCPv6. . . . . . . . : 00-01-00-01-16-BB-51-DD-5C-26-0A-20-9A
-92
   Serveurs DNS. . .  . . . . . . . . . . : 192.168.10.20
   Serveur WINS principal . . . . . . . . : 192.168.10.20
   NetBIOS sur Tcpip. . . . . . . . . . . : Activé
C:\Users\grbofr>ping 192.168.11.200
Envoi d'une requête 'Ping'  192.168.11.200 avec 32 octets de données :
Réponse de 192.168.11.200 : octets=32 temps<1ms TTL=128
But I can not ping the cisco SA 540.
C:\Users\grbofr>ping 192.168.10.254
Envoi d'une requête 'Ping'  192.168.10.254 avec 32 octets de données :
Délai d'attente de la demande dépassé.
I disable firewall on my laptop using Windows 7 X64 and we are not using firewall linked to antivirus.
Should I create a route on my laptop ? Or on the cisco AS 540 to access remote network ?
Is there a specific firewalling rule to create on it ? I do not setup anything.
Gregory
Just a note, I can not ping the gateway 192.168.11.1
Are you using Full or Split Tunnel on the VPN > IPSec > Dynamic IP Range page?  We are using Split Tunnel and found we had to reboot the device after selecting Split Tunnel and applying the change.
I configure it as full tunnel. As advised, I rebooted the device without success.
Some of our users had issues at some remote locations (like at Starbucks or other corporate environments) when we used Full Tunnel mode.  We had to switch to Split Tunnel and reboot the SA540 to ensure everyone gained access.  It also lessened the burden on our network because the Internet traffic wasn't being routed over the VPN connection.  I stopped troubleshooting after that.
Silver
Gregory,
Since you're still having trouble i would suggest giving the Cisco Small Business Support Center a call @ 1-866-606-1866 and open a support case with next available engineer. Also what Curtis was suggesting is a really good idea. Instead of full tunnel use split tunnel and reboot SA5xx and test.
Jasbryan
I tested split tunnel with reboot. I can connect but no gateway is given by the appliance.
Silver
Gregory,
You shouldn't have a gateway address -
Yeah give support a call @ 1-866-606-1866 and open a support case
Jasbryan
I have exactly the same issue with my new cisco SA 540.
Have someone find a solution for the vpn connection with cisco vpn client?
George
1202
