SA 540 Port forwarding
I have 5 static IPs from my isp and want to forward traffic from each IP to an internal NAT'ed IP.
MY SA 540-K9 is on 192.168.10.1 (the SA 540-K9 is not handling DHCP)
My DHCP server is on 192.168.10.2 and has vpn and sharepoint running fine on it.  I had an old Dlink firewall router that handled the port forwarding fine, it was just very very slow so we bought this SA 540-K9
I want to send all trafic from the following external IPs to the internal Nat'ed IPs
64.254.125.146 to 192.168.10.254 all ports for a VOIP phone system
64.254.125.147 to 192.168.10.2 port 1723 or  to allow windows vpn clients to vpn to a windows 2003 server
64.254.125.148 to 192.168.10.250 all ports
64.254.125.148 to 192.168.10.251 all ports
64.254.125.146 to 192.168.10.254 port 80 to allow web browser access to sharpoint running a windows 2003 server
The VOIP phone system works great, but no other firewall rules are allowing access.
Is there a place I need to add the additional WAN IPs before they can be added in the firewall rules since the only static IP in the SA 540-K9 is 64.254.125.146 as the WAN port and I am using that IP for the VOIP phone system.
Here is my current IPV4 firewall rules.
StatusFrom ZoneTo ZoneServiceActionSource HostsDestination HostsLocal ServerInternet DestinationLogEdit
EnabledWANLANPPTPALLOW alwaysAny192.168.10.2:172364.254.125.147Never
EnabledWANLANANYALLOW alwaysAny192.168.10.25064.254.125.148Never
EnabledWANLANANYALLOW alwaysAny192.168.10.25164.254.125.149Never
EnabledWANLANANYALLOW alwaysAny192.168.10.25464.254.125.146Never
EnabledWANLANANYALLOW alwaysAny192.168.10.2:8064.254.125.150Never
Thank you for any help,
Rob
  • Small Business Security
1 REPLY
Re: SA 540 Port forwarding
This is a known issue.  Please upgrade to the 1.0.39 firmware to fix this.  Also, read the release notes.  Upgrading to that version will require a factory default because of significant database changes.
1659
