SA500 1.1.42 firmware release posted on Cisco.com
Hi All,
Please find the firmware at  www.cisco.com/go/sa500software.
Biraja
Re: SA500 1.1.42 firmware release posted on Cisco.com
Hello.
I'm trying to download new  firmware for my SA 520W, but when I  add the software to the download  cart and press "Proceed with download"  I'm taken to a page saying:
Page Unavailable.
The Webpage you requested is unavailable.  Please revisit at a later  time. We apologize for the temporary  inconvenience.
So can I please come to a webpage where I can  download the latest  software for my Security Appliance? Thanx!
regards,  Artur
Hi Artur,
I could successfully downoad the firmware using "non java download option".
Can you try one more time, if not I can try to get it to you in a different way.
Biraja
Hi. Thanx for your response. I don't even get to choose java or non-java. I get a Internal Server Error before I can choose, and then the previous error message..
Do I need a contract with special access privilege to download this software update? I just bought this piece of equipment, and I haven't used this system before. I would be surprised if it's not possible to download firmware upgrades at least within a limited amount of time after buying this equipment...
Thanx, Artur
Hi Artur,
You need to have a previleged access.
Did you register with Cisco.com with your purchase order info? If not, can try to change the previleges?
If you can't access it still, please send your email id to biraja@cisco.com, and I'll get you the image.
Biraja
Does this release fix hair pinning????
Hi David,
If you are referring to the feature where hosts on the LAN accessing other hosts like printers on the same LAN with public IP, then this is not implemented in this release. We are tracking this for the future releases.
Thanks and Regards,
Biraja
Any idea how much longer? I am in desperate need of this.
David Grudek
Network Creations Ltd.
1325 Campbell Ln.
Hoffman Estates, IL 60169
ph: 847.975.7800
www.NETWORKCREATIONS.com
dgrudek@networkcreations.com
Hi David,
Firmware with NAT hairpinning will be available by end of this month.
Please bear with us for a week or two.
Biraja
728
