SA500 Firmware Upgrade
With the standby feature for firmware upgrades. Is the device configuration maintained for this update or does it factory default all the setting so you have to re-load your specific configuration?
Mike
Re: SA500 Firmware Upgrade
Nevermind, found the answer in a technical document.
To confirm you can choose to do the firmware update and keep your configuration or choose firmware update with factory reset in which your configuration will be cleared to factory settings correct?
Mike
Community Member
hi Mike,
You are correct.
Biraja
Community Member
When is the next version of the firmware going to come out for the SA520W?
This will be mid April.
616
