SA520 and SDSL
I try to configure a SA520 with an SDSL.
I configure the different IP address, mask and gw, and the connection seems ok.
I can ping everything on the web( ping www.google.fr, ping www.cisco.com), but when i start a browser, nothing happens, no surf ...
I try to configure the mtu, but with the old router, it is configure at 1500.
When i use an traditionnal ADSL, all is ok, but not with the SDSL ...
I se in the log file : size of this packet is lesser than minimum length
Component: KERNEL
eth1: Using 10Mbps with software preamble removal
Component: KERNEL
but this log are also here with the ADSL, and i can surf
Firewall conf
Default Outbound Policy
For IPv4:
Select Rules
From Zone:
To Zone:
List of Available Firewall Rules
StatusFrom ZoneTo ZoneServiceActionSource HostsDestination HostsLocal ServerInternet DestinationLogEdit
EnabledWANLANtseALLOW alwaysAny192.168.1.10WAN1Always
Attack Checks
WAN Security Checks
Block Ping to WAN interface
Enable Stealth Mode
Block TCP flood
LAN Security Checks
Block UDP flood
ICSA Settings
Block ICMP Notification
Block Fragmented Packets
Block Multicast Packets
DoS Attacks
SYN Flood Detect Rate [max/sec]:
Echo Storm [ping pkts./sec]:
ICMP Flood [ICMP pkts./sec]:
Content Filtering
Content Filtering Enable
Enable Content Filtering?
Web Components
Proxy:
Java:
ActiveX:
Cookies:
Thansk.
Re: SA520 and SDSL
Could you please try to reproduce the issue,
then PM me the log file ?
To collect logs from the SA520 router. Please log in to the SA520 router and
in the URL type with IP address https://IP_address_of_SA520/scgi-bin/dbglog.cgi
Also, what kind of the SDSL modem is connected to the SA520 ?
Wei
Re: SA520 and SDSL
Thank you for you answer.
The SDSL modem is a rad LA 110
Now the SA520 is behind an ADSL modem, and all is OK,but when i put the SDLS, no surf
I PM you the log file, but notice that it is with the ADSL
I can't put the SDSL modem this week, but when i will be able, i pm you the log file again
Can you just tell me, with the actual log file, if something is wrong, and can explain the SDSL bug ?
761
