SA520 not releasing SSL sessions?
I have a SA520W (1.1.65), currently with the original 2 seats of SSL sessions.
Often, my users will get the message at the portal indicating that there are no more sessions available.  However, when I log into the admin portal of the device, I don't see any active SSL sessions.
Restarting the device clears this up, for awhile.  Is it normal to need to restart the device every couple of days?  Seems pretty invonenient.
I plan to upgrade the license to the 25 seats, but is that just going to reduce the frequency of restarts?
Re: SA520 not releasing SSL sessions?
Hi Chris,
Can you send me a screen shot of the actual message you are recieving?
Thanks!
Dave
David L. Barrett, Jr.
Hi Chris,
Could you forward me the dbg log when this happens again ?
thanks
wei
I am having the same problem. Did this issue ever get resolved?
which version of the firmware are you using ?
Wei
I am using version 1.1.65.
This is a known issue with this firmware and is currently escalated.
I'll post any new findings I have soon.
479
