SA520 seems to terminate Telnet session
Question: We recently replaced a router with Cisco SA520. The connection is only used for a Telnet application. After replacing the router we experience the problem that the Telnet session is terminated after around one minute of inactivity in a way that it does not respond to keyboard input anymore. With out old router this happend after 30 minutes.
Everythink works fine as long as the user does actively use the system.
The SA520 is configured with a static external and internal IP address. Two ports are forwarded (515,9100) from the external side (where the Telnet server resides) to an internal printer.
Does anyone have idea what is causing this problem.
Thank you
Sascha
Everyone's tags (1)
1 REPLY
Re: SA520 seems to terminate Telnet session
Your timeout is probabally set very low.
TRY THIS:
Router(config)#line vty 0 4
Router(config-line)#exec-timeout 30
If you still have a problem please let us know.
NOTE:
I did the timeout for 30 minutes because that it what your old setting was.
663
