SA520W - Simultanenous IPSEC and SSL VPN?
Is it possible with the 520W to configure and run some clients as IPSec and some clients as SSL VPN connections?  Can these two types of VPN run simultaneously?
Everyone's tags (6)
1 REPLY
We have anywhere from 0 - 20 SSL VPN connections and anywhere from 0 - 20 IPSec connections working simultaneously on our SA540.
Tell us what your business needs are so we can better help you.  If it's just whether or not both types of SSL VPN connections can be used at the same time then the answer is yes.
719
