Community Member
SA540 and Netbios
I configured VPN on my SA 540 according to your document "SA500_vpnclient_appnote.pdf" so I can use the Cisco VPN client.
On my SA 540 I am running firmware 2.1.71
Behind the SA 540 I have 6 Windows 7 PC's running, so there is no DNS server. There is a WINS server running.
I can only connect to the shares on IP address and not by there host names.
I have noticed that when I log on to my SA 540 and I go to "VPN" and then to my VPN Policies and I edit the active policy, there is a tick box "Enable Netbios". Strangely enough I can not tick the box.
I want to enable this so my VPN clients will be able to connect to machines by there host name.
Please advise how to resolve this issue,
Kind regards,
Dave Diependaal
AB-Radio, The Netherlands
1 ACCEPTED SOLUTION
Silver
SA540 and Netbios
Dave,
When configuring the SA500 device for Cisco vpn client, this option is grey out because the client don’t support NetBIOS broadcast. Now the SA500 does give you the ability to configure DNS or Wins options so when SA500 gives out the IP address for the Cisco vpn client will have Wins server given.
Look under Vpn tab
Click on Dynamic IP range and put in optional settings for Cisco Vpn client. When the client gets an address it will include your Wins server you specify and you should be able to resolve computer names.
Hope this helps,
Jasbryan
SA540 and Netbios
Without looking into the reason why the "Netbios" setting is being greyed out,
As a quick work around you could add the netbios names - ip address setting to your lmhosts file on your PC (i.e. configure a hosts file)
Here is an example for Windows OS
http://support.microsoft.com/kb/101927
This is reasobable if you have only 6 servers, and the ip addresses of the servers do not change.
I suggest to open a case with STAC to find out if Netbios and Cisco VPN client is being supported or not.
hth  Jo
Community Member
SA540 and Netbios
Thanx for the reply Joachim.
Since we are a small non profit organisation we dont have a support contract with Cisco.
This means that I can not raise a TAC case :<
I would still like to know why I can not tick the "Enable Netbios" box.
SA540 and Netbios
I assume netbios is not being supported when using Cisco VPN client.
To get an answer please open a case here:
https://supportforums.cisco.com/docs/DOC-13250
Netherlands Phone Support: 0800 023 3416
You do not need a support contract when contacting STAC. The serial number of the SA540 is sufficient. You can open the case under warranty.
Silver
SA540 and Netbios
Dave,
Look under Vpn tab
Hope this helps,
Jasbryan
860
