SA540 DHCP server multi subnet ISSUE
i have SGE2000 is Core Switch it have 3 vlan
vlan 1 : 192.168.0.1
vlan 2 : 10.10.10.1
vlan 3 : 10.10.30.1
static route 0.0.0.0 / 24 next hop 192.168.0.254
SA540
vlan1 : 192.168.0.254
static route : 10.10.0.0/16 next hop 192.168.0.1
its connect with SA540 in ports 1st no vlan enable i config only static route back to core switch. now i want to use SA540 to assign IP for clients in every vlan it can.
i see vlan function and i enable and create vlan same the SGE2000 and create DHCP scope and disable Inter-vlan routing because i want to use routing cross vlan on SGE2000 , then clients on every can't access to vlan 1 but when i delete vlan on SA540 it ok , clients can access to vlan and can use internet.
have solution for this because i don't have dhcp server and in AP have multiple ssid , i think it must use dhcp because i can't fix ip for wifi clients
thank you for your support.
Everyone's tags (3)
Re: SA540 DHCP server multi subnet ISSUE
please help me for this issue,
Hi:
Based on your decription and configuration, I am suspecting there might be a routing loop.  Can you remove the static routes and disable the inter-vlan function in the SA to see if you still encounter the same issue?
If issue persists, can you PM your SA and your switch confguration?
Best Regards,
Charles
947
