Community Member
SA540 Latency issue
I have a SA540 and the last 4 weeks or so, I've been having latency issue.  I do have a VPN connection with the office and pinging to a PC at the office is around 13ms.  I've turn off IPS, content filtering, protectlink, etc. and still get the same result.  The office has a 100Mbps Internet connection.  Thanks for the assistance.
From my PC
Last Result:
Download Speed: 23635 kbps (2954.4 KB/sec transfer rate)
Upload Speed: 1519 kbps (189.9 KB/sec transfer rate)
Latency: 205 ms
Sat Nov 05 2011 07:33:11 GMT-0500 (Central Daylight Time)
Another PC in the house
Last Result:
Download Speed: 23605 kbps (2950.6 KB/sec transfer rate)
Upload Speed: 1526 kbps (190.8 KB/sec transfer rate)
Latency: 201 ms
Saturday, November 05, 2011 7:41:07 AM
Bypassing my Cisco SA540 FW and directly connect to ISP with my notebook.
Last Result:
Download Speed: 24111 kbps (3210.1 KB/sec transfer rate)
Upload Speed: 1641 kbps (230.1 KB/sec transfer rate)
Latency: 9 ms
Saturday, November 05, 2011 8:15:24 AM
Community Member
SA540 Latency issue
Disable ContentFiltering under FIREWALL - 11ms
Enable ContentFiltering under FIREWALL - 205ms
Disable ContentFiltering under FIREWALL, Enable WebThreatProtection under PROTECTLINK - 212ms
Disable ContentFiltering under FIREWALL, Enable WebThreatProtection and URLFitering under PROTECTLINK - 226ms
The SA540 is underpowered, Cisco support recommends not Enabling any filtering if latency is an issue for your applications.
Without content filtering, the SA540 is like any other firewall in the market.  SAVE your money and buy a Netgear, Sonicwall, ZyXEL, Watchguard, etc.
Silver
SA540 Latency issue
HD,
You mentioned that you called into the support center; what was your case number? I would like to review your case to see if any things else could have been done. We can also lab your scenario up and test for performance issues.
Jasbryan
Community Member
SA540 Latency issue
The original case is:  620259751 SA540 Latency issue
1499
