ab
SA540 memory upgrade
Hi all,
we are using a cisco SA540. The memory usage is very high ( 87% ). is it possible to add a memory module ?
1 REPLY
Bronze
Dear Alain,
Thank you for reaching the Small Business Support Community.
Unfortunately none of the Small Business devices were intended for memory upgrade, while enterprice devices are.  Just in case I suggest you to run the latest firmware version available, v2.2.07, so that we make sure the device is running on its optimal performance;
http://software.cisco.com/download/release.html?mdfid=282571097&release=2.1.71&softwareid=282728525
Please do not hesitate to reach me back if there is anything I may assist you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
428
