Community Member
UC 500 Behind SA500
Ok, So I have a new SA520 that I have installed in front of my UC500.
So not only do I loose 8 SSL seats, I have also lost SSL VPN support for 64 Bit OS's and Windows 7.
This does not help us and is two steps backwards.
Is there a way I can map through the SSL to the UC and get my 10 seats back and my 64 bit support?
Can I merely map port 443 through the SA to the UC and be good?
Re: UC 500 Behind SA500
Yogi,  I've asked for clarification on this from the applicable product team.  I'll be watching this with you for an answer.
Best Regards,
Glenn Q.
I didnt show SSL VPN passthrough, but it is possible as shown here...
https://supportforums.cisco.com/docs/DOC-9767
and value add here:
https://supportforums.cisco.com/docs/DOC-9777
Community Member
No this doesnt work for me.  This is the normal way to hook it up.  The issue is that not only do I loose my 10 SSL seats that I have on the UC, the SA doesnt support 64 bit clients or Windows 7.  So now that I have installed it, I cant run CIPC as my clients at home are either 64bit or Windows 7.
If I could pass the SSL traffic through the SA and on to the UC, I have 64 bit and W7 support and i have my 10 seats back.
The SA will support Windows 7 and 64 bit clients.  It is on the roadmap, but dates change so I can't say when this will happen.
I believe you can pass SSL VPN traffic by to your UC with the firewall.  I don't know if the VPN connection would work that way or not.  I would have to test it, but my lab is a bit busy right now.  Does forwarding the traffic work?
Community Member
I haven't tried anything yet, we too are busy, but frustrated that we put this in and it ends up breaking stuff...  I was hoping someone would know and save me some time with being the guinea pig
Community Member
So what about support on the SSL VPN for Mac Clients and Windows Mobile Clients?  these were 2 questions posed by a prospective client today.
I know that SSL VPN does work today with MAC clients.  I do not know about Windows Mobile, but I can ask about that one.  I am not sure that Windows Mobile is on the roadmap for this yet.
Community Member
Steven,
Any official word on the mobile support?  We tested in house and were unable to get it to work, so I dont think it is supported now.  What about future plans?
I have asked, but have no response yet.
Community Member
Customer is still waiting for a response on this before they buy?  Can you tell me about support for Mobile on the ASA?
There is no support today, not sure if it is on the roadmap or not for the SA500.
For the ASA, which uses the any connect client...
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/data_sheet_c78-527494.html
Requires an extra license, but it can do it.  Tested devices here.
http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect24/release/notes/anyconnect24rn.html#wp949979
1442
