Upload speed issue ASA 5500, please help.
Having a small issue upgrading from PIX 515 to ASA 5510.
What is weird is:
Switch > PIX 515 > Router:
     Down: ~30 Mbps
     Up: ~30 Mbps
Switch > ASA 5510 > Router:
     Down: ~30 Mbps
     Up: ~1.5 Mbps
Switch > ASA 5510 > PIX 515 >Router:
     Down: ~30 Mbps
     Up: ~30 Mbps
Any idea what could be the problem?
1 REPLY
Re: Upload speed issue ASA 5500, please help.
I would recommend you try using the netpro forums.  The products talked about in this support community branded Cisco Small Business and Small Business Pro.
Hopefully you can find what you are looking for here.
http://forum.cisco.com/eforum/servlet/NetProf?page=main
1388
