Community Member
VTI interface on ISA 570
Hello.
How to configure VTI interface on ISA 570?
1 ACCEPTED SOLUTION
Are you referring to just setting up a standard VPN, or are you referring to GRE over IPSec (VTI) as referenced at this link?
https://supportforums.cisco.com/docs/DOC-1228
If you're referring to GRE over IPSec, please see page 2 of this document and note that DMVPN and GRE are not supported.
http://www.cisco.com/en/US/docs/security/small_business_security/isa500/technical_reference/vpn/Configuring_VPN_with_Cisco_ISA500_Series_Security_Appliances.pdf
Shawn Eftink
CCNA/CCDA
Please rate all helpful posts and mark correct answers to assist others searching for solutions in the community.
Shawn Eftink CCNA/CCDA Please rate all helpful posts and mark correct answers to assist others searching for solutions in the community.
Shawn Eftink
CCNA/CCDA
Community Member
438
