WAN port configuration SA520w
We switched to another internet provider and have problem with our SA520w and a slow WAN connection on av fibre connection.
We have confirmed that we need to set/ force the WAN port interface on the router to use 10base-t (Full duplex) in order to get maxium speed from our Internet provider. Is there any solution force the router to use that settings as I cant find that alternative on the port setting page in router configuration?
Latest firmware installed
Everyone's tags (2)
1 REPLY
Re: WAN port configuration SA520w
You can change speed and duplex settings at Networking->Port Management -> Port Management.
Biraja
807
