Community Member
AVMS Freezes Computer?
Has anyone else experienced a computer freeze after running the AVMS software for 1 to 3 weeks?  Are there any known issues with this?
It is rather difficult to troubleshoot since the only way out is to power cycle and because of the freeze it leaves no logs that I can tell.
Thanks in advance!
1 REPLY
Silver
Re: AVMS Freezes Computer?
Harry,
Haven't seen any problems with AVMS software. Did you check to see if you’re running at least minimum requirements for the AVMS software?
http://www.cisco.com/en/US/prod/collateral/ps6712/ps9692/ps10533/data_sheet_c78-611567.html
Here is data sheet for AVMS software – near bottom is the hardware requirements:  minimum requirements.
Jasbryan
1635
