PVC2300 View over HTTP
We are trying to setup a program that has a window with the playback from the PVC2300.  If I setup the link as the IP of the camera (192.168.1.150) it show the entire home page.  How do you link to the camera output only?
Re: PVC2300 View over HTTP
Try http://192.168.1.150/media.sav
It comes up as webpage not found when I try that in Internet Explorer.  Do I need to change anything in the setup to make that work?
Do you want this to work from the LAN (local same VLAN as camera) or the WAN (remote)?
OK,
I set up a PVC2300 on a PoE Switch behind a Small Business router and enabled RTSP on the Camera and forwarded port 554 to the Static IP address of the Camera as a port forward rule on the router.
I then opened Apple Quicktime and selected Open URL
I typed:   rtsp:///mobile.sdp <--- (I apologize for giving you media.sav before since that didnt work)
the resulting picture (granted very low quality since this is intended for viewing on a 3GPP Smart Phone at low bandwidth cunsumption), but it worked.
For much better quality, I used the FREE SWVMS16 Monitor Utility which can watch up to 16 cameras remotely (powerful PC required for 16).
I usually watch 4-8 on my lap top while doing other things....
I attached that too....
I will give it a shot.  I will let you know.  Thanks for the help.
LAN
2850
