Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
PVC2300
Are there Cisco zoom lenses for PVC2300 for indoor factory environment?
1 ACCEPTED SOLUTION
Re: PVC2300
This camera does have a removable CS Mount lens.
Lenses are available in fixed focal lengths, variable focus lengths, motorized zoom lenses (usually with separate controllers)
An automatic DC iris is recommended for most applications but a manual iris lens can also be used.
Lens requirements:
Infra-red corrected to give focus in both day and night modes
Either ¼” or 1/3” lens
C-mount lens with a 5mm spacer (C-CS adapter) or a CS-mount lens
Some Cisco Lens part number you should find at DISTY:
CIVS-IPC-VF38        Fujinon 3-8mm Varifocal
CIVS-IPC-VT38        Tamron 3-8mm Varifocal
CIVS-IPC-VF31        Fujinon 3-11mm Varifocal
CIVS-IPC-VT31        Tamron 3-11mm Varifocal
CIVS-IPC-VF55        Fujinon 5-50mm Varifocal
CIVS-IPC-VT55        Tamron 5-50mm Varifocal
1 REPLY
Re: PVC2300
Lens requirements:
2223
