Recording Software for WVC210G ip camera
Hi all,
I have an issue with finding the Camera  Recording software.
we purchased the ip camera WVC210G and was searching  for the Camera Recording software 'L-VM300-04'  for viewing 4 Cameras.
But from Cisco and Distributor we came to know that the product has the EOL(End of Life)
So it would be great if anybody can  suggest the equivalent software for the same
Sooraj
1 REPLY
Gold
Hi Sooraj,
Thank you for posting. The Video Monitoring Software is developed by Nuuo: http://www.nuuo.com/
I believe that they have a similar product to L-VM300-04 and you can license the software from them if you can no longer obtain a license for the Cisco product.
1688
