RTSP on iPhone
Wondering if anyone knows about a program on the iPhone which can play the RTSP playback from the PVC2300 camera´s?? Or is there a workaround to get the iphone to work with RTSP??
Eivind
Everyone's tags (3)
Re: RTSP on iPhone
Since there is no native RTSP support in the iPhone, I haven't seen any applications that can view RTSP.  There are a couple of attempted ideas on how to make that work if you do a google search, but doesn't look promising.
Re: RTSP on iPhone
Davin,
Ok, thanks.
Eivind
Silver
Re: RTSP on iPhone
Actually, I've been able to successfully do this.  With both the Linksys and Cisco gear.  Mind you, it's on a jailbroken iPhone running a beta build of VLC media player.
I've been able to stream via WiFi, and both 3G and EDGE over IPSEC VPN ;-)
Cheers!
Scott Olsen Solutions Specialist Bulletproof Solutions Inc. Web: www.bulletproofsi.com
Re: RTSP on iPhone
Scott,
That's great. What about the app store? Can you post your app there?
Eivind
Silver
Re: RTSP on iPhone
Like I mentioned above,  it was on a Jailbroken iPhone running a beta build of VLC media player.  Last time I checked, I don't believe there were any Apple sanctioned apps capable of RTSP in the app store.  It would be wonderful if there were.  Obviously there's a demand.
Scott.
Re: RTSP on iPhone
There is an App in the AppStore called "LinksysCams" which you can buy (3,99 Euro). With this App you can connect to the video stream of all available small business video surviallance cameras (also wvc210) over the local wireless network.
Steffen
18031
