WVC210 AC Adapter Failure?
Been using the IP Cam for a few years now. Recently, the it no longer works. I think the AC Adapter has failed. It gets really hot and maybe the circuits cut power to prevent damage. I've turned the unit on and let it cool down overnight. In the morning, I try turning power on. The camera seems to restart and then gets turned off again. What else can I try?
Many thanks.
1 REPLY
Gold
Hi Jonathan,
I recommend that you replace the power supply as soon as possible to avoid any damage to the camera.
The Admin Guide specifies the following requirements:
5DVC 2.0A Switching Power Supply
- Marty
3214
