wvc210 camera display not working
I have a wvc210, the little LCD display on the camera is not showing anything so I cannot determine what IP it is working off. The indicator lights are working and it boots up ok.
Any suggestions?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Silver
Hello, First of all, I'm
First of all, I'm sorry that you are having issues with the camera.
My first recommendation if for you to contact the support center at 866-606-1866 so that we can determine if the device is under warranty and replace it.
If that is not an option or you already know the device is out of support and since the unit is working correctly, what you can do is look into the DHCP table and find the MAC Address of the camera, that way you will now the IP address that is using and will be able to log into it.
Also, if that is not an option, you could download a network scanner (several free on the internet, as always, Google is your friend), run the scan and find the MAC address.
Once you found the address, log into the unit and assign a static IP address to it so you will always know how to access it.
I hope this was helpful.
Silver
thank you for this. Your
thank you for this. Your suggestion was very helpful. I downloaded a scanner an was able to identify the camera and give a static IP address through the setup pages.
thanks again..
Silver
Hello, Thank you for letting
Thank you for letting us know that this worked, m glad you gained access back into the camera.
202
