Community Member
WVC210 Internet Explorer ActiveX issue
I've just got my Wvc210 camera installed, and when trying to setup the motion detection, it ask me to install an ActiveX plugin.
I can't install it, since IE tells me "
Windows has blocked this software because it can't verify the publisher.
Publisher: Unknow Publisher.
This is probably due to the fact that the expiration date has past for the SSL certificate....(valid through 11/07/2009)
Re: WVC210 Internet Explorer ActiveX issue
On IE8, go into TOOLS: OPTIONS:  Security tab, and then click on Custom settings and change from block to "Prompt".
Let us know if that works.
Steve
Community Member
ok, works.. I though this was enabled on the trusted site zone... anyway...
great!
Thanks for the confirmation.
Steve
Community Member
FYI: The expired certificate in the ActiveX component has been updated in the latest firmware.  Installing v1.1.0 will refresh the certificate date.
3200
