WVC210 WLAN Reconnect Broken
Dear,
I see the following erroneous behavior on the WVC210 (1.1.0.15) in regards to WLAN connectivity.
(1) device is wlan connected (dhpc)
(2) AP goes down for >1 hour
(3) device does not reconnect but self-assigns a private IP and becomes unreachable
Work-around: power-cycle the device upon which it reconnects to the AP.
Yet power cycling needs physical access to the unit which is not the case.
I already tried to log this issue 1 year ago. I tried logging a case but could not get a case number etc. Now with the almost latest firmware I see the very same issue which makes the device rather moot for wider use.
- a wvc210 tester
442
