02-06-2017 02:02 PM
Just as the title says, it is driving me crazy not being able to find what that letter stands for. I know these are 10G SFP+ DAC cables. Some companies write it as 10GBASE-CR which stands for:
10G = '10GbE'
BASE = 'baseband'
C = 'Copper
R = '64B/66B block coding for 10G+ speeds
What the heck does the U stand for???
Solved! Go to Solution.
02-06-2017 08:35 PM
The same question was asked on reddit 1 hour before your question here. The consensus seems to be copper, since Cu is the chemical symbol for copper.
02-06-2017 08:35 PM
