kt
Community Member
Boot image for SRW2024
Where can i download boot images for SRW2024?
Is it correct that i have to upgrade the boot image to install the 1.2.2 firmware?
1 REPLY
Community Member
Re: Boot image for SRW2024
You may not download boot images, they are only available through the SBSC. You will not require one. What you will need to be careful of is "a" and "b" versions. If by chance you have flashed the wrong version, you may use the xmodem procedure posted here to upload the correct one.
Christopher
1883
