Community Member
Can a SRW208MP be reset to factory defaults without a PC?
The IP address is unknown and we need to reset the switch. SInce we can't access the configuration menus. I was wondering if we could reset this device to factory defaults another way. I couldnt locate a reset switch.
Silver
Bob,
No you'll need a pc/laptop. You'll have to have a console cable connection to the switch to perform a factory reset on this device.
Jasbryan
Community Member
Re: Can a SRW208MP be reset to factory defaults without a PC?
thanks.....done
2369
