ā09-19-2014 07:00 AM
We have a few SG200 switches and I'm trying to configure the auto smartport macros for both the IP Phone and IP Phone + Desktop. Whenever I edit the macro and change the native VLAN to what I want (the Voice VLAN is correct just not the native vlan I want the desktops to connect to), I click Apply, but it automatically changes the native VLAN back to the default VLAN (in our case VLAN 1). I'm trying to change it to VLAN 2. Any ideas why it won't let me change the native VLAN? I can change the native VLAN on others, like switches, routers, printers, guest, etc. just not the above two and the Desktop one as well. Those three will not change for some reason. Thanks!
Solved! Go to Solution.
ā09-19-2014 07:28 AM
Hi Brademeyer29,
what you see unfortunately it is not configuration issue. This has been reported to the engineering team and should be fixed in the next release firmware 1.4.1.
For now you will have to use workaround such as not changing native VLAN or not to use smartport.
Aleksandra
Hi Brademeyer29,
Aleksandra
ā09-19-2014 07:56 AM
Thank you for the information! Is there a scheduled release date for that firmware release?
